Author Topic: MK3 Golf Anniversary (Operation OEM+) - Vandalism - Thanks Yeovil  (Read 337417 times)
Re: Flash Red MK3 Golf 20th Anniversary
« Reply #170 on: 01 May 2011, 20:59 »
So now all my gears apart from fifth don't work. Excellent. Driving home in only fifth was not fun and j don't think the clutch liked it at all.
Is it a linkage or gearbox problem :smiley:
Offline dom
  • Back in a Mk4
« Reply #171 on: 01 May 2011, 21:04 »
I'd still put my money on the linkage!
Offline neil1780
« Reply #172 on: 01 May 2011, 21:06 »
shady, have you considered public transport  :huh:
Class :grin:
V6 4MOTION
Offline Shady Pioneer
  • graphic designer.
« Reply #173 on: 01 May 2011, 21:06 »
Still very cheap chuff  :wink: I'll get this sorted hopefully soon, but funds are crap at the moment.
Offline dan_apps
  • too low for british roads!
« Reply #174 on: 01 May 2011, 21:48 »
sounds a nightmare! as wayne says do you know if its the linkage or the gearbox? have you had a look under the bonnet and checked the play in the linkage?
Offline Jack3559
« Reply #175 on: 01 May 2011, 21:50 »
Good luck dude... Think it's about time you had some automotive success.
  • graphic designer.
« Reply #176 on: 01 May 2011, 22:49 »
Temporarily fixed until I get a repair kit. The part that connects to the weight to the right, the end of that there is a hole (spline?) and the teeth had rounded. Also there is some play in selectin gears and this is due to the ball, not sure of it correct name but that part will be included in the repair kit. At least it's driveable for now.  :smiley:
Offline robz
« Reply #177 on: 02 May 2011, 09:12 »
That's good then, at least at ya don't have to pull the box off!!
Good luck!
  • graphic designer.
« Reply #178 on: 04 May 2011, 08:50 »
Good luck!
Yeah thankfully. Although I've had a horrible clutch smell over the past couple of days but not as strong as when I put it under strain in fifth gear.  :grin: Hoping it's just calming down after the onslaught I gave it.
New part has been ordered from VW, £9.69! Should have it tomorrow.
Offline robz
« Reply #179 on: 04 May 2011, 09:07 »
haha
give it a beasting with the new bit on, sure it be reet :D
