Author Topic: toothed belt  (Read 1506 times)
Offline mcgee9t2
toothed belt
« on: 25 April 2011, 14:20 »
was going to service my car today
firstly in my service schedule it says toothed belt change, take it this means cam belt yes?
also anyone know if vw are open today? or will they all be different weather they decided to open today?
Offline dom
  • Back in a Mk4
Re: toothed belt
« Reply #1 on: 25 April 2011, 14:28 »
Toothed belt will be cambelt; and your best bet is to pick up the phone and ring vw :wink:
Offline mcgee9t2
Re: toothed belt
« Reply #2 on: 25 April 2011, 14:30 »
cheers, so if at 85 k every thing was ticked except from brake fluid, which was done about a month ago,and its on 105k now i just need to change oil/oil filter/sump plug, air filter, spark plugs and petrol filter?
this is a mk4 1.8n/a btw, didnt put it in the mk4 section cause im guessing its pretty much the same across all the mk's and it will get seen more in here.
« Last Edit: 25 April 2011, 14:33 by mcgee9t2 »
Offline dom
  • Back in a Mk4
Re: toothed belt
« Reply #3 on: 25 April 2011, 14:40 »
It depends on time as well, cambelts can perish with age. When was the 85k service carried out?
Offline mcgee9t2
Re: toothed belt
« Reply #4 on: 25 April 2011, 14:49 »
around a year and a half ago
just noticed that spark plugs are under the "every 40k" part so dont need them doing untill 120k im guessing, unless someone couldnt be botherd to get them done
Offline dom
  • Back in a Mk4
Re: toothed belt
« Reply #5 on: 25 April 2011, 15:38 »
The belt should be fine then. I'd have a look at the plugs and see what condition they're in, if they look knackered replace them otherwise I'd be tempted to leave them :smiley:
Offline sharki786
  • GOT BOOST??
Re: toothed belt
« Reply #6 on: 25 April 2011, 17:06 »
id also have a look at the belt. as dom says, they cam perish with age and develove cracks and what not.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Re: toothed belt
« Reply #7 on: 25 April 2011, 19:59 »
Cam belt is every 40k or 4 years
