Author Topic: Removing lower timing cover  (Read 1576 times)
Offline motah33
« on: 25 April 2011, 03:27 »
Hi,
I need to remove the bottom timing cover (1990 Digifant 8v) and from what I can see, I need to remove the crankshaft pulley. I've taken off the nut+bolt that holds the bottom timing cover in place. I need to remove the 4 hex bolts by holding the centre crankshaft bolt with I think a 19mm socket? I presume this will come out and I can pull the timing cover off? When putting it back, will it only fit one way? Would I need new bolts plus some thread locker?
Thanks
Offline mk2bal
Re: Removing lower timing cover
« Reply #1 on: 25 April 2011, 21:12 »
I'm sure you don't need to remove the pulley to remove the cover, I'm pretty sure it comes off over it.. Think your missing a bolt. Check the whole perimeter of the cover and the centre 1 of course.16v anyway
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 25 April 2011, 21:48 »
8V and 16V you DO need to remove the pulley from the crank to get the lower cover off.
This means the four allen headed bolts and then tap it about a bit and it should come off.
DO NOT undo the big bolt in the middle!
Offline mk2bal
« Reply #3 on: 25 April 2011, 22:55 »
Are you talking about the v belt pulley or the crank (cambelt) pulley. The big v belt 1 will yeah (4 bolts), the cambelt 1 (19mm bolt) doesn't though
Offline mk2bal
« Reply #4 on: 25 April 2011, 22:57 »
Yeah sorry just read original post, it said hold the 19mm not undo it! Oops! Shouldve read it properly!
Offline Sam
  • Sam I am
« Reply #5 on: 26 April 2011, 17:09 »
Water pump pully and crank v pully need to come off
