Author Topic: thoughts please.....  (Read 1029 times)
Offline golfnut8v
« on: 24 April 2011, 19:36 »
any suggestions welcome...
just had the auld bus out for a good run....approx 130 miles..
travelling at approx 70 miles per hour..no problems.
stopped at the local take away van for a coffee, and went to start the car...
usually starts no probs, idles lovely,and runs sweet..
this time it farted into life for a second or so,second attemt the same ( sort of started but
stalled ) third time gave it a bit o juice .....started but felt lumpy and if it was on 3 cylinders..
when running for a few seconds and a few revs later all ok...
stopped again 10 mins later and same thing again.( never had any probs like this )
1990 mk2 golf gti..digi..pb engine code.
any thoughts guys...?
« Last Edit: 24 April 2011, 19:39 by golfnut8v »
Offline rob.043
Re: thoughts please.....
« Reply #1 on: 25 April 2011, 10:14 »
failing fuel pump perhaps. Mine did something similar when fuel level was low, as the lift pump in the tank was on the way out. About £30 for a new pump fixed it, easy enough to change. Would give no issues with a nearly full tank as the pump was doing less work.
Or it may be something completely different!
