Author Topic: stripey laquer?  (Read 3040 times)
Offline weazgti
stripey laquer?
« on: 23 April 2011, 21:34 »
Been outall day spraying laquer on a mettalic silver panel with a rattle can but everytime i do it it looks like its got dark stripes in it. Its more noticeable at certain angles and its starting to p*ss me off because ive redone it  3 times today.
Would the laquer compound back so its all the same?
The base coat looked fine.
Offline Thom89
  • Looking for an "Icebreaker"
Re: stripey laquer?
« Reply #1 on: 24 April 2011, 00:16 »
I suspect that you've been bollocking the lacquer on very wet, because of the heat, and trying to get a decent flowing finish... this is a problem with cheap acrylic lacquer, it tends to go cloudy when built up too quickly...
You may also be seeing a problem called "Floatation" this forms in the basecoat, and on lighter colours is usually invisible to the untrained eye, but is magnified when given a few coats of lacquer...
In my experience, today was just too warm to paint, especially with acrylic aerosols, wait for a temp drop to 15 to 22, and build up in lighter coats...
Thom
Offline weazgti
Re: stripey laquer?
« Reply #2 on: 24 April 2011, 17:38 »
so can it be cut back or will i have to do the laquer again.
I did it both ways i tried light coats and got stripes so like you say i did put sh!tloads on but still the same.
Offline Thom89
Re: stripey laquer?
« Reply #3 on: 24 April 2011, 22:45 »
Re paint, and re lacquer, only way out of it...
Carefully re flat the parts, here's the bad bit, if you break through the lacquer, you could have problems re applying the basecoat without it reacting with the previous attempt, so prepare very carefully!! grey Scothcbrite should be used to re key the paint...
Thom
Offline weazgti
Re: stripey laquer?
« Reply #4 on: 06 May 2011, 19:25 »
just done it again but still stripey like a reaction or something.I tried to flat first before i saw your last reply so i think i ballsed it up.
Think i did go through the laquer in  places because the stripes are in the same place everytime.
What should i do now? sand back and primer to stop this happening again?
Would upload a pic but havent got my phone lead with me
« Last Edit: 06 May 2011, 19:30 by weazgti »
Offline Thom89
Re: stripey laquer?
« Reply #5 on: 07 May 2011, 00:37 »
What is it you are trying to paint?
Thom
Offline weazgti
Re: stripey laquer?
« Reply #6 on: 07 May 2011, 21:56 »
Rear quarter on a 4 door. It had laquer peel so i sanded back till smooth then went from there applying basecoat again and laquer.
Should i of primered it first?
Offline Thom89
Re: stripey laquer?
« Reply #7 on: 08 May 2011, 11:33 »
A rear 1/4 panel is asking a lot from aerosols!! it just too big to get a decent finish, If you want to try again, then you would be best off taking the paint that you've  applied off, by either sanding, or rubbing it off with some thinners on a rag, (not recommended!) then re priming and painting... But in all honesty, I think you'll end up back where you started :sad:
Thom
Offline weazgti
Re: stripey laquer?
« Reply #8 on: 13 May 2011, 20:45 »
Cant beleive it. its showing through primer.
Whats next? bare metal it?
Offline Mac76
Re: stripey laquer?
« Reply #9 on: 17 May 2011, 23:33 »
The 'stripes' are probably in the base coat as some of the metallic particles aren't laying correctly and it probably hasn't flashed off.
To rectify it you'll need to redo the base coat and lacquer and chances are it will react.
You need to lay the base coat down in light coats almost dusting it on and do a drop coat on the final coat of base coat then when its flashed off do a grip coat of lacquer followed by 2 or 3 good coats of lacquer.
As thom89 said you're asking a lot of arsehole cans as most pros struggle with silvers and even some manufacturers silvers you can see light and dark bands
Any Qs just ask
Cheers Marc
