Author Topic: SUSPENSION KITS  (Read 2987 times)
Offline Fraiser
SUSPENSION KITS
« on: 08 September 2003, 12:14 »
I am thinking of buying a apex suspension kit 60mmm drop. It is going cheap cannot afford to miss thisone, can someone advise me i am currently runnig on 205/45/16s will the drop make the tyres rub etc.
Thanks for any advice.
golfvr6
Re:SUSPENSION KITS
« Reply #1 on: 09 September 2003, 18:20 »
Best to phone a company like C&R enterprises and ask for advice.
Offline Slim Shady
  • Thrash her like a ginger step child
Re:SUSPENSION KITS
« Reply #2 on: 10 September 2003, 10:05 »
Do you want some Sachs lowering springs chief?
I got a set - in my shed 8)
Offline GTI16vGaz
  • New car will be displayed soon.
Re:SUSPENSION KITS
« Reply #3 on: 10 September 2003, 16:50 »
Just a bit of advice, my mate had a 1989 GOLF GTI 16v he lowered it 50mm on 205/45/16s and it was catching when there was 3 people in the car.
Only when hitting a small bump on the road, on the flat it was ok, but where do you find really flat smooth roads.
Gaz
Offline GTI16vGaz
Re:SUSPENSION KITS
« Reply #4 on: 10 September 2003, 19:18 »
Are the springs 30 - 35mm lowering?
golfvr6
Re:SUSPENSION KITS
« Reply #5 on: 11 September 2003, 20:40 »
I would stay away from sachs springs, especially if they are from GSF.
Offline modulater
Re:SUSPENSION KITS
« Reply #6 on: 11 September 2003, 22:21 »
I would say it all depends on the ET of the wheels, if they are the same as the standard fit wheels you willprobably get away with not rolling the arches.
Most after market wheels are wider to make the car look better and as such will rub on the arches, 60mm is a lot to drop a car.
golfvr6
Re:SUSPENSION KITS
« Reply #7 on: 11 September 2003, 22:51 »
Yep , avoid the speed mountains(humps)  ;)
Offline Fraiser
Re:SUSPENSION KITS
« Reply #8 on: 12 September 2003, 18:41 »
thanks for all of your advice - i bought the kit but still deciding whether to put it in or not. they were a bargain ill maybe save them for something special.
golfvr6
Re:SUSPENSION KITS
« Reply #9 on: 14 September 2003, 20:41 »
I would fit the fronts and see how low it goes! If the ride is ok then do the backs. Good luck  :)
