Author Topic: Oil pressure ??  (Read 1377 times)
Offline Craigwilson
Oil pressure ??
« on: 23 April 2011, 14:51 »
I fitted a 0-10 bar oil pressure sender to a gti 8v engine to operate the pressure vdo but it is always reading low pressure and when the revs drop below about 2000 the idiot light comes on. Could this be because i need a 0-5 bar sender instead of 0-10.
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
Re: Oil pressure ??
« Reply #1 on: 23 April 2011, 20:11 »
Have you tried fitting it into the oil cooler,With a t-piece??
I had a similar problem and that sorted it
Offline Craigwilson
Re: Oil pressure ??
« Reply #2 on: 23 April 2011, 23:54 »
Will it fit in the space down there ? Ill giv it a try
Re: Oil pressure ??
« Reply #3 on: 27 April 2011, 10:31 »
check the ratings on the sender, it should have 1-10 bar and either 0.3 or 1.8bar stasmped on the flats. the 2nd reading tells you which sensor the vdo is supposed to replace. if it is the 0.3bar type then putting it in the head is fine, you just have a pressure problem to the head. i had the same with worn cam bearings
Offline Craigwilson
Re: Oil pressure ??
« Reply #4 on: 09 May 2011, 00:24 »
Thanks if you say the cam bearing caused a pressure problem in the head ill check them coz they do seem very clicky.
