Author Topic: M/C 22.5 or 20 mm ?  (Read 1467 times)
Offline emery1990
M/C 22.5 or 20 mm ?
« on: 23 April 2011, 11:47 »
Just got a master cylinder for my mk2 golf gti 16v. On the body it says 20, on the box it says 22.5mm, my old had 22 stamped it. Can I measure my new one anyway, or could a different m/c of been packaged in the wrong box.
Quick answer needed, gsf shut at 2! It looks the same size as the old one, but guessing the inside which is 22 or 20mm
« Last Edit: 23 April 2011, 12:00 by emery1990 »
Offline danny_p
Re: M/C 22.5 or 20 mm ?
« Reply #1 on: 23 April 2011, 15:16 »
if it has 20mm stamped on it it's 20mm
all the VW's have gone bar 1.
Offline emery1990
« Reply #2 on: 23 April 2011, 16:17 »
Yer they said early 16vs came with 20mm m/c ? I thought they all came with 22mm, swapped it over anyway. Nothings even coming out of the rear calliper now though, think it may be jammed, I can suck through the bit of piping and just a tiny bit of fluid comes out, my tyre is probably over the recommended 20psi as well.
Offline cняis
« Reply #3 on: 23 April 2011, 20:29 »
have you clamped the bias valve open? if not it will restrict the flow of brake fluid
Offline emery1990
« Reply #4 on: 23 April 2011, 20:32 »
No I havn't it is seized solid! Got some wd40 on it so will check in the morning if it'll free itself.
