Author Topic: Oil EVERYWHERE! ABF in Mk1 Breather pipe open to air...  (Read 2524 times)
Offline alhuyshe
Bought a car with an ABF engine fitted.
http://s151.photobucket.com/albums/s144/alhuyshe/?action=view&current=P1010436.jpg
There's breather pipe that has no pipe on it!
http://s151.photobucket.com/albums/s144/alhuyshe/?action=view&current=P1010436.jpg#!oZZ1QQcurrentZZhttp%3A%2F%2Fs151.photobucket.com%2Falbums%2Fs144%2Falhuyshe%2F%3Faction%3Dview%26current%3DBreatherPipeDetail.jpg
Choices:  Do I simply run it to a catch tank, or what would happen if I fed it into a Y pipe fitted to the pipe behind it that runs back into the inlet tract?
Offline Diamond Hell
  • Opinions я Us
Re: Oil EVERYWHERE! ABF in Mk1 Breather pipe open to air...
« Reply #1 on: 22 April 2011, 09:07 »
Run it in behind the air filter for the easiest solution, or to a catch tank.  It's a breather hose from the block, so will huff oil everywhere unless routed properly.
Offline alhuyshe
« Reply #2 on: 22 April 2011, 09:13 »
Thanks, mate!  So drill another hole into the tract between the air filter and the throttle body, and not try feeding it into the other pipe there?   Catch tanks are all very well, but they get full after a while...  More maintenance!
  • Opinions я Us
« Reply #3 on: 22 April 2011, 09:16 »
H'mmmm, think you should be OK joining in to that pipe, which I *think* is the ISV feed.
Might get more crud into the ISV though, rather than going straight to the inlet.
Offline alhuyshe
« Reply #4 on: 22 April 2011, 09:22 »
Straight to the inlet it is, then.
Thx
