Author Topic: squeak,squeak,squeak,squeak,squeak,squeak,ARRRRGHHH!  (Read 8304 times)
Offline GrandMstRamRod
im getting this terrible squeak noise from the front right hand side wheel, every time i accelerate turn a corner or just general driving, breaking it wont make the noise at all, it started to get loader, and loader, which is doing my head in, so much it turns heads when driving!
anyone got any ideas before i start stripping the whole right hand side or twitting it with  hammer! as god its starting to make me not want to drive it!
Offline Luke1981
Re: squeak,squeak,squeak,squeak,squeak,squeak,ARRRRGHHH!
« Reply #1 on: 21 April 2011, 14:14 »
Sounds like the wheel bearing to me   :smiley:
MK IV GT TDI 150 PD / MKII CADDY SDI
« Reply #2 on: 21 April 2011, 14:15 »
thats what me old man says, any danger or running it before replacing it soon, if it is that!
Offline makenzidiamonds
« Reply #3 on: 21 April 2011, 14:16 »
if it stops when ya braking probable some thing rubbing on the disc. probably a bit of road rubble or dust. give it a clean and get a wire brush and some brake cleaner on it. not likely to be a wheel bearing though cause it doesnt do it when your braking.  :wink:
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 21 April 2011, 14:25 »
my old golf had a similar noise and new brakes and bearings didn't solve it!
Try a bearing first and when fitting check you need to press the bearing onto the hub if it's not tight your best to buy a hub a.s.a.p as the new bearing will last weeks!
« Reply #5 on: 21 April 2011, 14:31 »
Wheel Hub (Right Hand) Part No.: 629440031 £23.94 -euro car parts!
bearing about 6 pound!
still reading haynes looks like a fatherless son of a job if it is that! :(
« Last Edit: 21 April 2011, 14:32 by GrandMstRamRod »
Offline cookymonster
« Reply #6 on: 21 April 2011, 15:10 »
also check the cv joint check if any splits in cv gaiter as if any sh!te gets in there it can fook them up
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 21 April 2011, 15:20 »
It's not that difficult but you will need a press of some nature to install the new wheel bearing. If you can't get access to one take the hub and bearing to your local garage and get them to squeeze it in for a drink.
Offline dan_apps
  • too low for british roads!
« Reply #8 on: 21 April 2011, 15:32 »
check the bearing first by jacking the car up and giving the wheel a good play about, use a pry bar to check for and movement from the ball joints etc aswell. might become clearer after this if it isnt the bearing.
Offline wrobstar21
« Reply #9 on: 21 April 2011, 15:45 »
Mine does this but only when turning right. I literally had the mot yesterday and all my bearings are ok. Had new one 6 months ago. Drives u mad, I'm gonna strip the wheel and have a look. Maybe something bent or needs greasing up
