Author Topic: idicator problems  (Read 1229 times)
Offline rossbarry1
idicator problems
« on: 21 April 2011, 12:52 »
i am having a prob with my indicators, the hazards work fine but when i idicate left or right they dont flash and also the led on the dash is permanantly glowing a dull green, is this a relay maybe...... Cheers guys
Offline cняis
Re: idicator problems
« Reply #1 on: 21 April 2011, 13:33 »
had this on my old mk2, the relay had started to come out of the fuse box. push it back in properly :afro:
Offline delirical
  • Like a g60
« Reply #2 on: 21 April 2011, 14:06 »
Dont mean to crash the thread but my indicator isnt cancelling these days... simple solution?
« Reply #3 on: 21 April 2011, 14:08 »
sounds like a faulty hazard switch to me, but check the fuses. where is the hazard switch, dash or column?
as for indicator cancelling this is probably down to the stalk, it has a plastic peg which pops out when you put the indicators on, this has probably fallen off or the springs for it have come loose
Offline delirical
  • Like a g60
« Reply #4 on: 21 April 2011, 15:36 »
Jonny, your a legend as usual. I forgot to mention its an intermittant issue, only happens sometimes with left hand down... will check what uve said tomorrow, may be the spring is on its way out..?
