Author Topic: Why does my valver rev so high?  (Read 1686 times)
Offline pegasus
« on: 22 March 2005, 18:38 »
Is this common? :undecided:
When the car is started, it revs to about 2000 rpm b4 settling out at 1000.
Surely it cant be good for the engine, being revved from cold.....
Does every 16v do this?
If not , how can i stop it, is it something to do with the isv?
Thanx in advance? :smiley:
1.8 20VT GTI
Offline thedentist55
Re: Why does my valver rev so high?
« Reply #1 on: 22 March 2005, 21:13 »
Yeah my valver does this aswell.  The last bloke who owned it had it from new and said that he brought this issue up with the dealership and they said this was correct function and that there is no need for any accelerator pedal action when starting (from hot or cold).  Does it do it when hot aswell?
Offline tinman
« Reply #2 on: 22 March 2005, 23:41 »
its an age thing. they do this when they get a bit older.
if you change the distributor pack, coil, and most of your fuel system it wont do it. bit extreme for a non fault.
reving from cold - you should stay under 3k in theory until the oil temperature starts reading on the MFA. You shouldnt really be in megamode until about 85degrees.
Offline AudiA8Quattro
« Reply #3 on: 23 March 2005, 00:07 »
Its probably just a naff ISV.
Offline Gambit
« Reply #4 on: 23 March 2005, 09:49 »
rising to 2k then settling down to idle is std operating on the 16v
its part of the cold start process, on startup the rev's will rise to 2k before settling down to idle. as said a dirty ISV can make it rise and hold that bit higher/longer. try cleaing out the ISV with petrol or cellulose thinners
i also assume part reasoning behind this is to make sure there is a initial good oil flow round the top of the head
if you want to experiment. disconnect the ISV and try and start your car in the morning by just turning the key - you'll find it aint easy to start and it sure as hell wont idle!!
Offline pegasus
« Reply #5 on: 23 March 2005, 17:15 »
Excellent, thanks alot for your input guys.
If its supposed to do it then thats cool, i may give the isv a clean out anyways.
@ tinman - it never gets revved past 3k until engine is warm m8  :smiley:
@ thedentist55 - it doesnt happen when warm, no.
@ Gambit - u seem to know what ur on about, think i'll be at u for advice in future  :tongue:
1.8 20VT GTI
