Author Topic: VERY high exhaust emissions - MOT fail  (Read 5253 times)
Offline k-ro
« on: 19 April 2011, 18:57 »
Basically, everything is way too high!
CO, HC & lambda are all ready massively high. MOT tester says they are the higher hes ever seen.
Before we start replacing parts, anyone got any idea why all of them would be so high?
fyi,
CO level = 8.19%
HC level = 413ppm
Lambda - 0.79
Kev
Offline MaXXeH
  • Golf MK5 GTI
Re: VERY high exhaust emissions - MOT fail
« Reply #1 on: 19 April 2011, 19:38 »
u got decat?
Offline houston
« Reply #2 on: 19 April 2011, 19:41 »
first thing to do is scan it to see if theres any fault codes. how longs it been since its been serviced?
Offline daz veedub
  • Operation 1.8t bolf
« Reply #3 on: 19 April 2011, 20:28 »
+1 scan, service if needed and check is de-cat on
Offline AudiA8Quattro
« Reply #4 on: 19 April 2011, 20:32 »
Failed ecu coolant temperature sender.
« Reply #5 on: 19 April 2011, 21:05 »
^^ This, replace it as a 1st step.
Offline k-ro
« Reply #6 on: 19 April 2011, 21:06 »
Standard cat on.
Serviced just over a year and a half ago, but a couple of oil and filter changes since.
It's getting scanned for errors tomorrow, just trying to get a few clues in the meantime.
I thought temp sender, but can that throw all those out so much?
Cheers all
« Reply #7 on: 19 April 2011, 21:07 »
Yes as it will think it is cold and dump in more fuel.
Offline mouth0502
« Reply #8 on: 11 July 2011, 18:00 »
sorry new to the site unsure how to post how did you resolve this issue mine is doing the same thing cheers adam :cry: :cry:
« Last Edit: 11 July 2011, 18:02 by mouth0502 »
Offline AaronGS
« Reply #9 on: 11 July 2011, 22:31 »
Would a failed temp sender show up on VAG-COM?
