Author Topic: Autosmart highstyle  (Read 3288 times)
Offline sch01
Autosmart highstyle
« on: 18 April 2011, 16:27 »
I'm sure this is the name of it, anyways got myself some of this to mostly use as a tyre dressing, can this be used on black plastic bumpers etc aswell
Thanks in advance
Offline Guy
Re: Autosmart highstyle
« Reply #1 on: 18 April 2011, 18:59 »
Thanks in advance
yes.. it certainly can... but... it won't last very long and will might streak when it gets wet
your best bet from the autosmart range is trim ultra.. needs about 4 hours to cure but provides a very long life finish
Offline sch01
« Reply #2 on: 18 April 2011, 21:08 »
Ok m8 I'll look out for some of that stuff & just keep the highstyle for tyre dressing
Offline Dan J
« Reply #3 on: 18 April 2011, 23:35 »
yep as Guy said it can be used but streaks and doesnt last long on plastics,
i mix my highstyle with megs indurance tire gel at 50:50 ratio, it gives the highstyle longer legs on tires;)
Offline Mr Blue
« Reply #4 on: 24 April 2011, 19:05 »
I found that highstyle doesnt mix very well?
I use it neat on tyres and they last nearly a month!. Its rubbish on plastics though.
Offline Dan J
« Reply #5 on: 24 April 2011, 22:25 »
what were you mixing it with?
ive been mixing it like this since megs bought out there endurance tire gel and havent had any grief with it just better results in terms of little to no sling off.
