Author Topic: GTI 8v 1996 flat spot...please help  (Read 1291 times)
Offline deano968
« on: 21 March 2005, 21:40 »
Hi, i recently purchased a Golf GTI 2L 8v 1996, problem is i have a flat spot on it, if the car is stationary and i accelerate sharply the engine dies for a second or so before increasing the revs. When driving sometimes a slight judder can be felt especially at low revs in a high gear, also (but not very often) when at tickover the revs will drop slightly then pick back up to the normal 800 rpm. It looks as though the car has recently had new plugs and leads and a new coil. Any help or advice would be greatly appreciated, many thanks.
Offline davidhawkins_78
  • Valver Bad Boy
Re: GTI 8v 1996 flat spot...please help
« Reply #1 on: 22 March 2005, 09:26 »
I'd be checking for air leaks first ...
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline deano968
« Reply #2 on: 23 March 2005, 23:40 »
Thanks, got it booked it to the garage tomorrow, if they cant find the fault i'll try what you suggest. Thanks again  :smiley:
