Author Topic: quick hand brake question  (Read 1084 times)
Offline the_stink
  • A3 140 TDI
« on: 14 April 2011, 17:29 »
just been looking for some guides and came across something that id thought id check ,
are there 2 hand brake cables? in all the posts ive read the op has said 'cables' so i assume its one for each rear caliper?
ive already bought one so do i need another?
the one ive bought is:
http://www.eurocarparts.com/handbrake-cable
Offline delirical
  • Like a g60
Re: quick hand brake question
« Reply #1 on: 14 April 2011, 17:51 »
I would also like to know the answer as mine is fooked, currently leaving it in gear everywhere i go   :sad:
Offline the_stink
  • A3 140 TDI
« Reply #2 on: 14 April 2011, 17:54 »
x2 and my MOT is end of may so need to sort as much as i can now, car makes a funny noise when braking so goign to replace the pads and disks when i get paid, getting some mk3 calipers from a guy on ed38 so fingers crossed that solves it
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #3 on: 14 April 2011, 18:05 »
Yes.  Each caliper has its own cable.  If you pull back the carpet covering the handbrake you will see the threaded screws holding them.  This is where you adjust the length/tension also.
