Author Topic: need help can u change the crankshaft r they interchangeable 18.16v  (Read 3387 times)
Offline danny_p
they won't have reground the cranck if they did it on a ramp.   cranck needs to come out the engine for a regrind   if it's ate another set of sheels quickly it prably beacuse they didn't clean the journals up before fitting the shells or they did clean them up but didn't bother to check them for size and fitted new shells to overly work journals   so it probaly needed to come out for a regrind  or you can replace the cranck  tho you may need to have the replacement cranck ground.
if you get stuck for a cranck  drop me a PM have a load of them somewhere
all the VW's have gone bar 1.
Offline kkerry2005
cheers 4 your help ppl  the work begins monday stripped cleaned and new crank ;-) if i get stuck will drop u a txt hahhahaahhaah lol thanks again ppl
Offline kkerry2005
found problem  :smiley: some1 put the shells in wrong  :sick: hopefully done by next week
How the hell do you fit shells wrong  :smiley:
Offline mk2bal
And you worked at tsr?? Shells have to go in a certain way round for oil to get in, and the notch has to be in the right place to stop them turning. Unless you're being sarcastic of course....
Offline danny_p
or you can put them in upside down as in plain shell in the block and the with with the oil hole in the bearing cap.
seen that done before
I was, I know it can be done and have seen it done, just wondered how a garage could get it wrong.
Offline mwep201081
Just cause something's idiot-proof doesn't mean it's cnut-proof
