Author Topic: Rear beam question.  (Read 1792 times)
Offline SI74
Rear beam question.
« on: 12 April 2011, 16:33 »
Am in the middle of givin my rear beam the once over its going to the powered coaters soon so am looking to order in a few bits.. Want to use all new parts so will be getting this lot below BUT it all I'll need???
Top rear strut mounts
Rear stub axles
New wheel bearings
N 010 241 24 - Caliper carrier bolt, M8x22
191 615 611 D - Brake disc shield, left
191 615 612 B - Brake disc shield, right
191 501 639 A - Stub axle dust cap
N 044 755 3 - splash shield/stub axle bolt, M8x55
321 501 119 A - splash shield bolt washer
N 905 173 04 - Bottom strut bolt, M10x75x45
N 102 090 09 - Bottom strut nut, M10
N 903 544 01 - Pivot bush bolt, M12x1.5x122
N 903 237 06 - Pivot bush nut, M12x1.5
N 101 417 01 - pivot bracket bolts
Also should I put in new standard bushes or after market one (if so what ones)
Thanks
Offline rob.043
Re: Rear beam question.
« Reply #1 on: 12 April 2011, 18:49 »
Just replaced my rear axle with a powder coated one, only used new stub axle bolts, as they were too nackered to re-use, and new brake lines.
So consider adding copper lines and flexi's to the mix. There is the brake bias valve back there too, so if your feeling flush, maybe you want to change that too. If you decide to buy new braided flexi's, you may even go all out and get some 'anti seize' mk4 calipers on there with the conversion hoses.
Some of what your replacing may be unnecessary, the old items may be perfectly serviceable, but at least you wont be caught out having everything!
What bushes you use is down to a personal choice....
If you value comfort, stick with standard genuine bushes, they will always feel better than nackered old ones, good if the car is a 'daily'. Polybushes will increase harshness. Possibly by a noticable amount, possibly not. Ive just put poly's on mine, as they were on the replacement beam I got, and my car has already begun down the poly bush route before due consideration. Ive not driven it yet, so cant comment yet....
Offline Mr Blue
« Reply #2 on: 12 April 2011, 22:27 »
I went for OEM bushes. - 191501541 bonded rubber mounting
Bais valve from euro parts.
871511423 - rubber mounting / for models with rear anti-roll bar (25)
321501119A - concave spring washer (3)
N 90877301 - hexagonal head bolt (4)
M10X32 /
Probably worth saving the cash if the stub axels are ok?
« Last Edit: 12 April 2011, 22:31 by Mr Blue »
Offline SI74
« Reply #3 on: 13 April 2011, 06:44 »
Thanks for the replies..  The stub axels are a right mess, like the most of the stuff on the beam.. Where did you get that pic from?? Or is there a list any where that says what each number is??
Offline SI74
« Reply #4 on: 13 April 2011, 18:39 »
its ok I found the web page with it all on dam theres a lot to to it.
« Reply #5 on: 14 April 2011, 09:10 »
I would stick with standard bushes.
