Author Topic: Headgasket!  (Read 8974 times)
Offline Sam
  • Sam I am
Re: Headgasket!
« Reply #20 on: 13 April 2011, 18:55 »
Or join club gti and its only a tenner  :grin:
Offline RyanVW
Re: Headgasket!
« Reply #21 on: 13 April 2011, 19:01 »
one other thing mate, once head is off you will need to check if has warped and get it skimmed as necessary, otherwise the new gasket will blow in no time
will it be obvious if the head is warped?
Thanks
Offline raferackstraw
Re: Headgasket!
« Reply #22 on: 13 April 2011, 19:32 »
get a straight edge and lay it across head and then shine a torch beam at where the edge meets the head, from the opposite side to the torch see if you can see light thru where the edge is against the flat metal of the head, do this all across head. or take it to a good machine shop and get them to check n skim as neccessary
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline Guy
Re: Headgasket!
« Reply #23 on: 17 April 2011, 18:35 »
yeah... but the mk1 OC I have found to be very useful  :drool:
