Author Topic: Door handles /lock mechanism  (Read 978 times)
Offline shaolindan
« on: 11 April 2011, 13:23 »
I replaced the two rear door handles while also putting on armour door plates. I started left rear and worked my way round. I had a little bit of difficulty with the locking mechanism on the drivers door, but if you move the door mechanism so it thinks it is closed it is all good.
I then went round to all the doors and checked them...... Guess what, the very first one, the rear left I have put in incorrectly. So I can open it. If I pull the pin up and then try either the indoor or outdoor handle, it pulls the pin back down instead of opening the door....   :sick:
I'm guessing that I will have to take the inside panel and membrane off, in order to release the mechanism, so that I can open the door and unscrew the handle.......
Unless anyone knows a cunning trick?
Golf GTi 8v mk2 1990
Coilovers, BBS RA, K&N Induction Kit...
Offline tattooroo
Re: Door handles /lock mechanism
« Reply #1 on: 29 April 2011, 10:27 »
the handles are left an right handed, it you remove the handle you can reach the latch through the handle hole
hope this helps
