Author Topic: 2 widow makers, bad life choice?  (Read 2654 times)
Offline Jimbop
« on: 09 April 2011, 10:31 »
I put new alloys on my golf the other night in the dark, in my haste I forgot to check treads were right way round on the tyres, so I now need to change the front two wheels over.
Is using a jack on each side and quickly swapping them over gonna be ok or should I just take the time of doing one wheel at a time and putting my old wheels on in between swapping?
Thanks
Jim
"The customer is always right" - Except when they're wrong.
Offline lewis1641
  • stuck in the 90's
Re: 2 widow makers, bad life choice?
« Reply #1 on: 09 April 2011, 10:34 »
do one side at a time. or spend £20 on a trolley jack. they are much safer plus lifting the front usually gets the rear off the ground too
Offline dom
  • Back in a Mk4
« Reply #2 on: 09 April 2011, 11:55 »
This for sure   :smiley:
Offline Jimmy Filth
« Reply #3 on: 09 April 2011, 12:01 »
Not if you lift both sides of the front...  :grin:
7R 5 door.  Limestone Grey.  19" Pretoria's, Leather, DCC, Winter pack, keyless entry, rear camera.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 09 April 2011, 15:11 »
Jack one side up, remove wheel. put spare on, jack other side, and swap wheels over, back to other side, remove the spare, and replace with wheel to swap :laugh:
Thom
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 09 April 2011, 18:21 »
buy a decent trolley jack.. i personally have the clarke racing one and love it  :smiley:
Offline cняis
« Reply #6 on: 09 April 2011, 21:11 »
someone needs to produce a low entry 2 ton trolley jack for sensible money! im fed up of double-jacking!
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 09 April 2011, 21:16 »
whack an old wheel under the subframe etc when it's jacked at least when the widow maker fails you'll have some protection
I had a friend killed when a decent trolley jack failed while he was under a car without anything else and a wheel may of saved him?
Offline Adam
« Reply #8 on: 09 April 2011, 21:19 »
Heres another story, flat surface, MK2, widow maker jack and a mate trying to adjust his coilovers with the wheels on. 4 Hours at hospital and a few crushed bits later. His forearm was crushed between the arch and the wheel.
It got worse after that! Bruising to hell.
Down Hill From Here.
Offline Dan_GTi8v
« Reply #9 on: 09 April 2011, 22:30 »
get a trolley jack, I use the one from halfords
