Author Topic: Where's the fuel filter? Mk1 gti cab.  (Read 1309 times)
Offline g8lf16v
« on: 08 April 2011, 15:31 »
Where is the fuel filter on my golf mk1 cab 1.8 k-jet?  Can't find it anywhere, how do you replace it?
Offline raferackstraw
Re: Where's the fuel filter? Mk1 gti cab.
« Reply #1 on: 08 April 2011, 17:23 »
will be the silver cylinder mounted beside the metering head in the engine bay, look to the rhs of engine bay and you will see a block with fuel lines on the top of it, the filter is mounted on the side
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
« Reply #2 on: 08 April 2011, 23:49 »
Pull the fuel pump fuse or relay and run the car until it cuts out, this releases the pressure in the fuel system then change as required.
