Author Topic: boot leaking  (Read 6818 times)
Offline SoundillusioN
Re: boot leaking
« Reply #10 on: 08 April 2011, 09:05 »
where is the water gathering in your boot?
I see where you're going with this I think, my cabby leaked a little from the back end of the roof!
wasn't thinking about leaking from above  :lipsrsealed:
Damn Cabbys, they can leak everywhere!  :lipsrsealed:
I have a tintop and my boot leaks too!  :cry:
hey i can see daylight when I am in mine with the roof shut!!  :laugh:
well der.... it does have windows!  :rolleyes:
Offline Guy
Re: boot leaking
« Reply #11 on: 08 April 2011, 09:57 »
yeah... but they aren't supposed to be in the middle of the roof above my head!
Re: boot leaking
« Reply #12 on: 08 April 2011, 10:42 »
Wow, check you out with your cabby with added sunroof!... I would say it must be a rare mod but it probably isn't.  :grin:
Re: boot leaking
« Reply #13 on: 11 April 2011, 09:41 »
on mine there were 2 sources of leaks, 1 was the seals round the rear lights and the other was the rubber seal around the rear window. the rear rubber needs a good squirt of sealant all the way round it otherwise it will never seal right, if the roof has been done recent and no sealant was put in then thats why.  you need to use a special type of sealant that doesn't go off as such, rather than boggo silicone stuff
Offline g8lf16v
Re: boot leaking
« Reply #14 on: 13 April 2011, 00:54 »
What type of sealant should I use? cheers
Re: boot leaking
« Reply #15 on: 13 April 2011, 10:36 »
not sure of the name, the stuff i had was made by wurth and was black. thick gloopy stuff and like i say it doesnt set
