General discussion
mk4 gti lowering help
Topic: mk4 gti lowering help (Read 1676 times)
pogi22
Just got here
06 April 2011, 22:54 »
got a mk4 gti lowered on coilovers about 75mm, how can i get it to go lower, what would i need to replace
daz veedub
Forum addict
Operation 1.8t bolf
Re: mk4 gti lowering help
07 April 2011, 20:20 »
you could take the adjusters out the rears if u havent already
Telf
07 April 2011, 20:31 »
arb would need changing or removed as it will foul on the driveshaft
remove helpers from front coils and as mentioned adjusters out the back
notch chassis (same reason as arb upgrade)
slam it !!
daz veedub
Forum addict
Operation 1.8t bolf
07 April 2011, 20:35 »
it will be rubbing at 75mm unless adjustable droplinks are already on or arb removed
Wayne
Sir Postalot
07 April 2011, 20:38 »
For a everyday car 75mm is a lot, much lower and you will start to affect how it drives / handles.
Telf
07 April 2011, 20:39 »
Quote from: daz veedub on 07 April 2011, 20:35
or arb that goes under driveshaft, ie whiteline or r32/4mo
General discussion
