Author Topic: Broken Electric Window!!!  (Read 3252 times)
Offline T1 VDUB
  • All work and no play makes Jack a dull boy
« on: 19 March 2005, 16:41 »
 :angry: Damn...  :cry:
Took my car for a spin around Newlands Corner, Surrey!! Amazing drive... Had the sunroof down, windows down - so to get the wind in my hair  :laugh:
Anyway... got back and the drivers side windon will not go back up... It is stuck in the down position and cant get it to a garage before Monday.
I have taken the door trim off and tried to manually get it into place... after having a vision of splintering glass shooting into my face I gave up on that.
If anyone has any idea's would be good to hear them
Is this likely to be electrical or a broken motor or something else? Thanks guys  :cry:
16 Valve
Offline Mr Blue
Re: Broken Electric Window!!!
« Reply #1 on: 19 March 2005, 16:47 »
yeah man been about witht the sunroof open and windows down too  :cool: :grin:
Slam the door and change the switch over and see if it goes back up?
anyway back to crusin time ill catch u later :laugh:
Offline T1 VDUB
« Reply #2 on: 19 March 2005, 16:49 »
Im running down to the car now....   :laugh:
16 Valve
Offline T1 VDUB
« Reply #3 on: 19 March 2005, 16:59 »
 :angry: damn damn damn  :angry:
Didnt work... thanks for the help any way... Im trying to fix my car and watch the welsh Beat the Irish...  :laugh:
16 Valve
« Reply #4 on: 19 March 2005, 19:07 »
Ok does the switch on that side light up?  When you press the switch do you hear any noises/clicks from the motor?
Try wiggling the rubber boot between the door and car body, common place for wires to break.  If that don't work take the door card off and try pressing the switch whilst you give the motor some light taps.  If all that fails try wiring the motor direct to the battery, and if that fails then the motor has gone!
Offline dubslug
« Reply #5 on: 19 March 2005, 23:16 »
on mine my motor stopped working but as soon as i loosened the bolts holding it in place it worked again, worth a try??
hope it helps
1992 pearl grey 8v
« Reply #6 on: 19 March 2005, 23:46 »
Yeah if you can hear it click then its most probably jammed, I had the same with my girlfriends AX cos she hadnt used it for months.  Stripped it down, gave it a few taps and all was well.
Offline T1 VDUB
« Reply #7 on: 20 March 2005, 18:43 »
 :cry: I have tried moving the rubber case between the door and the body with no joy,
there is no noise from the motor when you press the switch,
it makes no clicking noises... How would I wire the motor direct to the battery.
Thanks guys  :wink:
16 Valve
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
« Reply #8 on: 20 March 2005, 20:29 »
 :laugh: i had this happen to me but mine was the fact it didnt want to go down  ( after me an the gal had a row in the car she slammed the door shut  :angry: ) it didnt work for two days then it miracuesly strted working and ive not had any trouble since strange one i even took the switch off and cleaned the contacts this did sod all!!!
Offline T1 VDUB
« Reply #9 on: 20 March 2005, 21:37 »
 :laugh: Thanks Jetta,  :wink:
I will take the girlfriend out to the car, open the door and then provoke her by saying "she looks fat in that dress"...
:cool:
I will keep you posted :grin:
16 Valve
