Author Topic: Removing old front suspension strut  (Read 2544 times)
Offline k-ro
« on: 05 April 2011, 22:04 »
Hi all. After successfully removing the passenger side. I got severly stumped on the drivers side. The suspension are drops about 2 inches less than the other side.
Since had a read up on a guide and it seemed the case on that one. Is this true for all 1.8t's?
Anyway to do it, or does it have to be spring clamps or droppping the subframe?
Can anyone point me towards the bolts to drop the subframe?
Kev
Offline tech1889
  • Mk2 GTI FTW !!
Re: Removing old front suspension strut
« Reply #1 on: 05 April 2011, 22:16 »
i dont understand your problem ?? the struts should be an easy removal
Offline andc1
« Reply #2 on: 05 April 2011, 23:30 »
you need to undo the 2 main sub frame bolts, dont need to remove them just undo thwm halfway
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 06 April 2011, 06:54 »
just wind the spring compressors up a bit more and push the shock up and out, works for me :wink:
The smaller amount of travel is down to the driveshaft
Offline Rhyso
« Reply #4 on: 06 April 2011, 10:11 »
Drivers side was always a twit to remove on mine and Dave's golfs  :angry:  Bear in mind that Dave works on buses so is used to removing far bigger suspension components!
Offline b1gdub
  • MK4 1.8T AGU
« Reply #5 on: 06 April 2011, 12:22 »
undo the droplink and just keep using a hammer on the hub and watch the it drop away from the shockabsorber
