Author Topic: strange drivers side water leak behind servo!  (Read 2948 times)
Offline Simpson
  • one day il learn
« on: 05 April 2011, 22:02 »
Right as always struggling with a leak on the golf! this one has one on the drivers side coming through where the wires go through the bulkhead behind the brake servo. Car is mk2 golf, any ideas, how to fix this? Has anyone else had this problem? thanks :smiley:
i must buy a new car!
Offline X4MGS
  • VAG Parts SNOB!!!
Re: strange drivers side water leak behind servo!
« Reply #1 on: 05 April 2011, 22:06 »
Split Gromit, or nor sat in place properly..
For More Info Click To See;
« Reply #2 on: 07 April 2011, 10:38 »
prob not from the grommet as water doesnt get back there really, suspect the problem is higher up. either the bonnet release cable or the blanking plate over the LHD blower housing hole. take the ecu bracket out and have a good look under and around it in the scuttle area
Offline Simpson
  • one day il learn
« Reply #3 on: 08 April 2011, 14:11 »
its defo coming through the grommet as I have alreayd sealed the bonnet release and the ecu spare plate up, i have poured water and it defo seems to flow off the turret down there! I cant get to them due to the servo and master cylinder in the way. Thanks
Offline Ant1981
  • Feed me, prod me
« Reply #4 on: 08 April 2011, 18:01 »
Check your scuttle panel, right in the corners, there'll be a small drain hole. There's a drainage pipe that runs under the wheel arch from that hole and if that's blocked, which they tend to do after a while, the water won't drain from the scuttle and it'll enter the car.
I had this problem on my MK2, so cleared the drain with some stiff electrical cable by pushing it down and rinsing with a hose.
'09 Kawasaki Ninja ZX-6R
Offline Simpson
  • one day il learn
« Reply #5 on: 08 April 2011, 19:26 »
cheers didnt realize there was a pipe there, thought the only drain pipe was from the sunroof? is that under the fron or the back fo the scuttle? thanks again
Offline Ant1981
  • Feed me, prod me
« Reply #6 on: 09 April 2011, 00:28 »
Can't remember exactly, but I seem to remember it being right into the corner, so possibly at the back, can't remember if there's some trim to remove in the scuttle or not, but you'll soon see when you start to look for it, you'll probably see a collection of dirt which may be what's causing the blockage.
Offline Simpson
  • one day il learn
« Reply #7 on: 10 April 2011, 20:32 »
cheers there is no blockage there, its quite a big hole at the front of the scuttle. im almost definite its coming through the wiring grommet though somehow.  :smiley:
Offline Ant1981
  • Feed me, prod me
« Reply #8 on: 10 April 2011, 21:37 »
What happens if you pour water there? Does it come out of the inside of the wheel arch?
« Reply #9 on: 11 April 2011, 09:36 »
if water is getting behind the servo when you pour watyer in the scuttle, you have a rust hole somewhere under there. the scuttle ashould be totally sealed to the bulkhead on the inside of the bay, water should ONLY drain out of the drains either side of the scuttle where the side repeater wires go to the inner wings
