Author Topic: MFA clocks in my MK2 1.3c  (Read 1804 times)
Offline Andyfitz
« on: 18 March 2005, 21:47 »
Hey guys and gals!
First post here is about fitting a set of MFA clocks to my 1987 Golf 1.3c
I removed the clocks from another golf the same as mine, I was scrapping it as it was rotten behond repair (couldent beleve it ether ;)) So it's gone now.
I was rushed for time and dident get a chance to trace all the wires.
My question is this.. I know it can go in the car but how and what do I need to rewire?
I have the stalks and clocks of a VDO make, I have a standard 1.3c Golf and a urge to put them in it!
Any help would be greatly appriciated.
BTW car pics will be online tomorrow for you all to view also with a breakdown of my project ;)
Thanks again!
Re: MFA clocks in my MK2 1.3c
« Reply #1 on: 19 March 2005, 19:01 »
If the clocks are the 2 plug (early) type they'll fit straight in and work fine apart from the MFA.  To get the MFA going you'll need to read this:
http://www.thepaty.plus.com/8v/howto/install_MFA.htm
Offline Andyfitz
« Reply #2 on: 19 March 2005, 19:53 »
Yep there the early type :) I wanted the rev counter more than anything, so if it's all gonna work appart from the MFA then I will throw them in and wire the MFA up when I can be arsed.
BTW will the MFA display the time without wiring up the rest?
« Reply #3 on: 19 March 2005, 20:03 »
Yup the rev counter will work and the MFA will display the time :)
Offline Andyfitz
« Reply #4 on: 19 March 2005, 20:06 »
Quality :)
Thanx guys
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 20 March 2005, 17:40 »
I'll be putting a rev counter cluster in my 1.3 when I finally get it over here
