Author Topic: Sets of blanks for pressure testing AUM. *RESURRECTED*  (Read 1612 times)
Offline Big Tone
If I had these for sale would anybody be interested?
« Last Edit: 13 March 2012, 10:10 by Big Tone »
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
dellenty69
Re: Sets of blanks for pressure testing AUM.
« Reply #1 on: 03 April 2011, 22:19 »
yes i would be mate, that's if they had the compressor attachments as well?
Offline 20v
« Reply #2 on: 03 April 2011, 22:31 »
me toooooo
Offline Mac76
« Reply #3 on: 03 April 2011, 22:56 »
Me as well
Offline Big Tone
« Reply #4 on: 04 April 2011, 08:52 »
When you say compressor s attachment, whay so you mean?
I wil have a bit of a think today and put something together this week.
dellenty69
« Reply #5 on: 04 April 2011, 12:31 »
its to do a leak test isn't it, so you need a compressor attachment to be able to connect the compressor to fill the system with air.
Offline Big Tone
« Reply #6 on: 04 April 2011, 13:13 »
I understand that, but what do you mean exactly? a quick release connector? isolation valve (which is what I would use)? what size? 3/8" 1/2" 1/4"????
need to know what you have on your compressor, or i will just supply isolation valves, probably at 3/8"BSP fitted into the blanks for filling and venting purposes.
Offline Big Tone
« Reply #7 on: 13 March 2012, 10:09 »
Resurrected!!!  :grin:
Forgot about these so had a bit of a play at the weekend, what do you think?
TIP inlet with gauge, micrometer valve and air line fitting.
Turbo outlet/charge pipe inlet elbow "blank" threaded to accept the valve/gauge assembly and blank for blocking off the TIP breather return. ("puck" inlet)
This is a prototype, used with no problems, secure and does the job well, the finished will be a machined finish and all pipework/valves will match.
« Last Edit: 13 March 2012, 12:03 by Big Tone »
