Author Topic: Water Pump which is Hot outlet?  (Read 1686 times)
Offline bmouthboyo
« on: 02 April 2011, 15:31 »
Hi guys,
Silly question I know but on the pump is the connection by the thermostat fitting the hot outlet or cold return?
I am trying to bleed coolant system on T25 camper that has mk1 dx engine fitted but having problems
thanks
Offline bmouthboyo
Re: Water Pump which is Hot outlet?
« Reply #1 on: 04 April 2011, 10:52 »
Anyone? Just need to check its plumbed up right.
Is the connection with the thermostat in the hot output or cold return?
Thanks
« Reply #2 on: 04 April 2011, 11:37 »
top one is output, bottom 2 are return
Offline bmouthboyo
« Reply #3 on: 04 April 2011, 19:58 »
Sorry I am confused as I cant tell whats top and bottom  :embarassed:
My pump as 2 smaller connections and a larger one that has the thermostat fitted inside.
Is the one with the thermostat inside a cold return?
Offline mk2bal
« Reply #4 on: 04 April 2011, 21:46 »
Top is upwards, towards the sun, and bottom is downwards towards the tarmac
Offline Sam
  • Sam I am
« Reply #5 on: 05 April 2011, 00:32 »
One must assume that the pump is in his hand and not attached to an engine
Offline mk2bal
« Reply #6 on: 05 April 2011, 13:08 »
I know I'm only kidding on
« Reply #7 on: 07 April 2011, 10:36 »
thermostat hole is bottom :)
