Author Topic: vr6 oil temp to hot?  (Read 2145 times)
Offline tweed
« on: 02 April 2011, 12:14 »
oil temp at 60mph is 96. 70mph it's 98. boot the car and it goes to 106 but straight back down to 98 when cruising.
water is always at 70  :huh: something ain't right here.
Can anyone help me with this.
oil level is fine. It had rebuilt bottom end and new head gasket 4000 miles ago.
and If I turn heaters on, temp drops to 94 but I shouldn't have to do that.
it's a 95 mk3 with 81000 miles
Cheers tweed
Offline danny_p
Re: vr6 oil temp to hot?
« Reply #1 on: 02 April 2011, 12:45 »
oil normal   water a bit cool if anything
often wonder why vw botherd fitting oil temp funtion to the mfa just make ppl paranoid
all the VW's have gone bar 1.
Offline emery1990
« Reply #2 on: 02 April 2011, 12:47 »
Mine gets up to 116 mate, but my water does go 3/4 when it is this hot.
Are water pumps one speed, guessing they are.
Offline tweed
« Reply #3 on: 02 April 2011, 12:52 »
just used to gti's I guess. I knew the vr6 would run hotter but didn't take much to get it to 100.
water is low. But the front arch liner's are taken out so I guess that will make it a bit cooler.
Well I'm happy now  :smiley: Thanks for the fast reply dude's
Offline danny_p
« Reply #4 on: 02 April 2011, 14:24 »
water pump speed is related to engine speed as it's driven by a belt from the cranck.
temp should sit dead center of the gague if it dosen't thermostat isint quite right.
« Reply #5 on: 02 April 2011, 17:14 »
That sounds about right for the oil temp tbh.  :smiley:
