Author Topic: 1800 16v (KR) checklist.  (Read 2936 times)
Offline G-T
« on: 18 March 2005, 01:44 »
Right after much consideration i've chose to go Route KR, a friend is currently dropping a VR6 into his Mk2 16v So the engine is surplus... I'm going on a mates judgement here and he reckons the engine is fine.? I know for a fact its a lil smokey when given some but the most important bit is there is no knocking etc and it runs fine.
Would anybody do me a quick checklist on things I'll need from my mates 16v in order to convert mine to a 16v, i'm going to use K-Jet inj system for the time being untill i can afford something a lil more Full bodied? :cool:
After reading random post's I think I'll need:
Engine
Box
Driveshafts
256mm Brakes (already have)
Fuel lines ? ? ? <-? Can anybody advise
Fuel pump's<- Will i need a new fuel tank as well or can i use the current one and drop the internal fuel pump into it?
Is that all for the mechanical stuff, my next problem is the wiring.? The engine is from a CE2 (90 spec) golf, So for ease of use would it be fairly easy to convert to ce2 wiring??
Sooo many questions.
Cheers if u can help - GT
Ohhh important bit... Mines a 1987 F reg Golf 1.3
« Last Edit: 18 March 2005, 01:56 by G-T »
Veedubgt18v
Re: 1800 16v (KR) checklist.
« Reply #1 on: 18 March 2005, 19:29 »
just a quick question! why build something you can buy? it would be cheaper (insurance etc) to sell you car and that engine and stuff and buy a 16v.
Offline G-T
« Reply #2 on: 19 March 2005, 17:17 »
Find me a sunroofless Golf, small bumper 16v with manual windows / No central locking etc and i would lol.
Offline chubby
« Reply #3 on: 19 March 2005, 19:49 »
you will need
engine , gearbox, driveshafts, engine mounts , fuel pump in tank, main fuel pump, exhaust, engine wire loom, rear wire loom ( from rear lights fuel pumps etc), idle control unit (behind centre console and wireing to it) , relays, fuel pipes as they are bigger, heatshield at bulk head to stop brake fluid boiling up , dash loom and fuse box , rear disc brakes , compencator, brake servo , re route rear brake pipes for compensator, black box in (under scuttle panel) drivers side , gear linkage (inc pole from gear box to gear knob) as your will be too short, bigger battery, suspension upgrade as 1.3 too soft and sloppy, anti roll bar front, also preferable rear axle for rear anti roll bar, hand brke cables if converting to rear discs, coil, radiator, cooling fan, 14 inch wheels or bigger, cant think of any more but if i do i will tell you . you will not need the fuel tank as pump fitts in .  just did this conversion on my golf last year. all goes ok.  it is easyier if you have a doner car as i did.
you wont get all these parts from your freind as he will need some for his conversion.
have fun!!!!  :grin: :grin:
Veedubgt18v
« Reply #4 on: 20 March 2005, 00:15 »
look around they do exist, but they will be d platers or e platers
Offline Veedub1989
« Reply #5 on: 20 March 2005, 17:32 »
weren't lecky windows and central locking standard fitment on valvers and dont all MK2 GTi's have sunroofs?? Hence y I cant find me a black headliner for my 16v (previously a 1300cc)???
VW Golf 1989 2.0L 16v
Offline Gambit
« Reply #6 on: 21 March 2005, 14:52 »
they werent all lecky windows and PAS but there where all sunroofed
Offline sportline_velly
  • Quick hairdressers car...you knows it
« Reply #7 on: 21 March 2005, 15:27 »
no, i had a 89 16v with PAS, sunroof but no power windows :huh:
Velly
16v Sportline 145bhp/135lb.....its all about the torque!
ClubGTI Newport Regional Host
Offline Gambit
« Reply #8 on: 21 March 2005, 16:16 »
i have an 89 16v with electric windows and no PAS : :grin:
Offline Dannyd
  • LOOK AT THAT VALVER GO!
« Reply #9 on: 21 March 2005, 16:31 »
i have elecy seats, windows,PAS, central locking, and sunroof in early 90  :tongue:
wacked up on scuby snacks!
