Author Topic: Front indicator not flashing?  (Read 1980 times)
Offline Tramp
« on: 30 March 2011, 16:45 »
Front indicator not working. Bulb is fine, fuse is fine, I can’t see any bad corrosion in any of the plugs etc.
Emergency flash lights working on all (including the rear indicators and one indicator)...I think it might be a short but where is the obvious place it would be?
It’s a 1989 F plate Mk2
Offline mwep201081
Re: Front indicator not flashing?
« Reply #1 on: 30 March 2011, 18:58 »
If the 4 way flashers are all working then work from the stalk forwards.....
Offline Tramp
« Reply #2 on: 30 March 2011, 19:06 »
Not sure if you understood but the Hazards did work but only the 3 and not the faulty indicator. i have worked from the stalk but can discover nothing but i will go through it again who knows?
Thanks :wink:
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« Reply #3 on: 30 March 2011, 21:11 »
check the block/join about a foot back into th loom behind the light unit.It maybe broken or corroded
Offline Tramp
« Reply #4 on: 30 March 2011, 21:19 »
Now that might be it. I have to replace the water hose into the block but its such a small leak i keep putting it off!..... :smiley: :wink:
Offline 01664gti
« Reply #5 on: 30 March 2011, 21:21 »
just feel down behind the indicator you will find it
Offline Tramp
« Reply #6 on: 31 March 2011, 05:15 »
Sadly not. I had checked this before but it fitted in with the leak but i double checked and it is fine  :angry:
