Author Topic: Lost performance has returned!!!!!!!!!!!!!!!!!  (Read 4919 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Lost performance has returned!!!!!!!!!!!!!!!!!
« Reply #10 on: 12 April 2011, 15:48 »
Thats what i mean Nick has seen a few be sold with ebay housings from CR turbos which is no good.. Go turbo dynamics a much better company
Offline Grand Master Patch
« Reply #11 on: 12 April 2011, 21:38 »
How much are we talking for RS6 internals on the ko3s?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #12 on: 12 April 2011, 21:49 »
Think that would be custom so would need to call.. unless a company offer it as a option  :wink:
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #13 on: 14 April 2011, 16:24 »
CR Turbo's charge around £500 mark for a K03 hybrid using the RS6 K04 internals and if you send a K03s without any damage to the housing then you will have no issues. They also fit a Cosworth actuator.
I called Turbo Centre who quoted me near £800 for the same work
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #14 on: 15 April 2011, 09:38 »
CR turbos are good when they get it right, but it seem they are just chucking turbo together from parts laying around, then when things go wrong the blame the customer for oil starvation, or if the dont make power the blame the tuner.  I have a few mate who are tuners who now refuse to work with any car with a cr turbo fitted.
http://www.seatcupra.net/forums/showthread.php?t=298188
http://www.seatcupra.net/forums/showthread.php?t=298190
 01455 617233
« Reply #15 on: 13 May 2011, 18:49 »
Well today the car started to play silly buggers,coming onto boost just before it spikes it's cutting power and stuttering.
Scanned and as usual not a single fault :laugh:
Any idea's?
Offline RTechUK
« Reply #16 on: 14 May 2011, 00:03 »
Any idea's?
Could be coil pack or Ignition map which is an easy one to test imo.
But it could be lean burn missfire from a weak fuel supply.  This could be down to a blocked fuel filter, duff fuel pump, naff FPR or even the vac line split the the FPR.  You really need to find someone with a mobile wideband lambda sensor and do a log or get on a dyno for a logging session with a wideband andlive fuel rail pressure logging.   If you want you can pop down to me and I will carry out a full fuel system logging session and pin point the fault.
Nick
 01455 617233
« Reply #17 on: 14 May 2011, 14:22 »
I'll change the fuel filter and check for split pipes in a while,it is missfiring on boost.
I'll see how i go after the filter is swapped,and report back.
Offline RTechUK
« Reply #18 on: 14 May 2011, 16:02 »
No problem m8
 01455 617233
« Reply #19 on: 15 May 2011, 17:50 »
Good news,it was a split pipe that comes off the charge pipe and goes to the N75.Got that sorted and it's back to normal.
Now that's sorted,it's time to think about the forge actuator.How much fitted and fettled Nick.
I can feel a road trip coming on
