The garage
front wheel noise when i reverse hlp plz
Topic: front wheel noise when i reverse hlp plz (Read 3299 times)
17gti
16 March 2005, 23:16 »
ok i was wondering if anyone will now what is wrong with my car wheel when i reverse and only when i reverse there is like a strange noise comeing from the front wheel like a knocking i was wondering if that couled be the wheel bearing going but it only does it when you reverse when you drive the car normally its fine thanks and how much if it is the wheel bearing will it cost me thanks
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: front wheel noise when i reverse hlp plz
17 March 2005, 16:34 »
It sounds like one of your pad retaining springs is missing, its designed to stop the pads moving about when you reverse. Not sure how it does it, but something to check once you take the wheel off
17gti
18 March 2005, 17:31 »
if the reverse gear was going whould it make that noise land judder the wheel when slow reverseing help need asap
rubjonny
10k hero
18 March 2005, 17:41 »
Possibly, it could also be a clutch problem or perhaps your engine mounts are shafted!
17gti
18 March 2005, 17:52 »
a macanick said to me that its the reverse gear that is makeing the noise what noise would a reverse gear do if it was on its way out and if it is the reverse gear how much will it cost fix
rubjonny
10k hero
18 March 2005, 18:19 »
Its possible some of the teeth are damaged giving you a jerky reverse, no idea what it would sound like. If its knackered then only option is to get a reconned gearbox I'm afraid!
17gti
Reply #6 on:
18 March 2005, 18:25 »
how much would that cost me to get could it be a wheel bearing
rubjonny
10k hero
Reply #7 on:
18 March 2005, 18:31 »
No idea, tral ebay and visit your local breakers yards to see how much they charge. Doubt its a wheel bearing as it would be the same driving forwards!
First thing I'd try is replacing the front engine mount, then the 2 rear ones.
17gti
Reply #8 on:
18 March 2005, 19:25 »
would the wheel bearing cause the car to pull to on side like mine does
golf1.8t
GTI forum regular
Reply #9 on:
20 March 2005, 20:44 »
theres no way its a wheel bearing if its only when you reverse then theres a good chance its the gbox but have you noticed it while turning etc it could be the cv joint
DUBBIN FOR LIFE:
The garage
