Author Topic: HELP needed with adaptors!  (Read 1351 times)
Offline bonny
« on: 23 March 2011, 22:27 »
OK so i bought a set of 18" scircco Interlagos Alloy's for my mk4 golf. I have also bought a set of FK 15mm adapters 5x100-5x112 for them to fit.
My question is when i have bolted the adaptors to the hub & then fit the alloy with my wheel bolts they seem to be to long & dont tighten up the alloy properly  :shocked:
Do you have to get shorter bolts for them to fit tightly to the hub??
Craig
The more you pay The faster you go.....
Re: HELP needed with adaptors!
« Reply #1 on: 23 March 2011, 23:47 »
Yes I believe so or trim a little off :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 23 March 2011, 23:49 »
get a flap disk on a grinder and just grind some off
