Author Topic: Glove Box removal  (Read 1999 times)
Offline J_B
Glove Box removal
« on: 05 September 2003, 16:41 »
Help needed again - I am going to fit a 6cd changer into the Glove Box of 1991 Golf GTI (16v if it makes a difference)
There are about 8 screws you can easily undo that loosens the glove box but does not allow it to be removed - is there a trick to this or are there more parts of the interior that have to go before the glove box will come out
Reason I want to remove it is that I would rather the changer was secured in the glove box rather than rattling around
John
golfvr6
Re:Glove Box removal
« Reply #1 on: 07 September 2003, 10:16 »
You may have to remove the trim under the glovebox to get at some hidden screws or there maybe studs holding it in. When i changed my airbag on my mk3 for a glovebox, the airbag had studs on it, but as far as i remember the glovebox was just held in with screws.
