Author Topic: fault codes !  (Read 1456 times)
Offline loopyloo28
fault codes !
« on: 22 March 2011, 18:53 »
 ok i got my fault code reader through and i just update you on the problem first,, basically i drive it everday and can go ages before it kinda judders or stall whilst driving as if its running out of fuel but i always keep it topped up and it did it few days ago with a full tank
codes are ;;;;;;;
00544----------maximum charge air pressure exceeded
00561----------mixture adjustment control
16487----p0103------mass or volume air flow circuit-high input.may be due to a low
16500----p0116------engine coolant temp circuit-range/performance problem
cheers guys
Offline andc1
Re: fault codes !
« Reply #1 on: 22 March 2011, 19:33 »
wipe them off then run it and see what comes up then
Offline loopyloo28
Re: fault codes !
« Reply #2 on: 22 March 2011, 19:37 »
i did and got same codes 4 times !
Offline richw911
Re: fault codes !
« Reply #3 on: 22 March 2011, 20:04 »
 16487----p0103- = fooked maf   http://www.golfgtiforum.co.uk/index.php?topic=94783.0
16500----p0116- Temp sender fooked http://www.golfgtiforum.co.uk/index.php?topic=88088.0
The other codes ie mixture will be because of the other two faults  :wink:
Offline loopyloo28
Re: fault codes !
« Reply #4 on: 22 March 2011, 20:12 »
shall get them done asap   thanks rich your a star hunnie  :kiss:
Offline richw911
Re: fault codes !
« Reply #5 on: 22 March 2011, 20:32 »
No problem :afro:
