Author Topic: A car to match my Mk2  (Read 3602 times)
Offline Diamond Hell
  • Opinions я Us
Re: A car to match my Mk2
« Reply #10 on: 22 March 2011, 11:16 »
Don't be perverse, Wayne - the G60 is about the torque, not the BHP.
Provided you swap a new/properly rebuilt charger in on a regular basis it should be fine.  It's the high-milers that have given the reputation for failure.  People simply didn't expect to have to get a major item like that rebuilt as a service item (and why should they?)
It's indicative that VW didn't fit the 280mm rotors on the 16V, only the G60.
FWIW my vote would be buy an 8V and then transplant a 1.8T or if you want to be cheap (and keep the handling balance), an ABF.
I'd also budget for an LSD, but then I'm a fan of lots of traction.
Offline Haribo!
« Reply #11 on: 23 March 2011, 09:52 »
Well I ended up buying an 2ltr 8v, and im very impressed, its not a great deal different when it comes to speed, if anything its faster, its more responsive for sure, and still good on petrol... I kinda miss the golf but its nice to have something different.
Offline tony_ack
« Reply #12 on: 25 March 2011, 21:44 »
I went from a MK2 16v to a Corrado VR6 and never looked back. Fuel and parts cost a lot more in the VR though (and parts are expensive for Corrados in general).
The Golf is raw, but the Corrado is so much nicer to drive, and well balanced (now that the front engine mount has been upgraded!)
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #13 on: 25 March 2011, 23:49 »
2.0 16V is a good all round choice.
no they arent.
theyre sh!t slow, use lots of fuel, and use a mildly tweaked version of the not that reliable k-jet.
ive run 2x g60's as dailies for a total of about 2 years, and the only issue has been an engine mount (which i snapped on a trackday).
even a standrad, non pullied g60 with 160bhp feels massively better than a 16v. Then its just a case of a chip, pulley, exhaust and filter to see 185-200ish
ive never driven a vr corrado but can imagine it would be about the same as a 'stage one' g60, only with added fuel costs.
  • Opinions я Us
« Reply #14 on: 26 March 2011, 08:53 »
What did your G60s deliver MPG-wise?
Offline Sam
  • Sam I am
« Reply #15 on: 26 March 2011, 11:10 »
G60 has too many issues with the superchager to be considered a day to day choice, VR is really nice but think of the fuel bills.
Really? I know a few peeps who've run standard G60's (and G40 polos) as dailys just fine. It's only when you start pushing them with smaller pulleys etc that they get a bit un reliable.
Nick
Some can be ok but they still suffer lip seal problems and you then loose boost etc, yes you can rebuild them but I still think the 16v is still the best all round choice.
Also the standard G60 is only 24bhp more.
Thats why you dont have a standard one  :grin:
Offline Chris-White
« Reply #16 on: 26 March 2011, 11:12 »
on a run, without the chip, i got 40mpg on the screen of the blue one (probably real world mid thirties). With the gwerks chip / pulley high 20's early 30's. pushing on dropped that significatly.
with the newman cam fitted, well, dont ask  :lipsrsealed:
the red one with an sns 'Stage 5' was getting 25ish, but never really got taken on many long runs.
Offline tony_ack
« Reply #17 on: 26 March 2011, 21:49 »
From experience, VR6 is a little sluggish low down in standard guise - the MK2 KR, though slower, felt so much more lively from the off, though the VR takes off from about 3.5k rpm. For all that, expected MPG around town and on the commute is about 25mpg, and it will settle in the low thirties for a quiet motorway run
G60's can also be modded pretty cheaply, whereas on the VR you need to get a Schrick manifold, 268 cams and a remap to make it come alive, or supercharge/turbo it if you can afford it. I've just put the Schrick in mine and it's transformed the car, brining in the power much earlier.
Costs-wise you have a charger overhaul every 60000 miles on the G60, but then there's the chains on the VR6 every 100000 miles or so which cost £1500+
1995 VW Corrado VR6
