Author Topic: How does the washer pump work?  (Read 3853 times)
Offline Gloves88
« on: 21 March 2011, 21:44 »
This might be a really stupid question but I cant work it out....
I've fitted a washer bottle and pump in the rear of the car and have identified the wires I need to run to it.
I believe the wiper stalk just reverses the polarity to the motor to pump the water to the front or rear but what I dont understand is, there's only one water "exit point" on the pump so how do I connect the water pipes to ensure the front and rear will work correctly?
Offline tech1889
  • Mk2 GTI FTW !!
Re: How does the washer pump work?
« Reply #1 on: 21 March 2011, 21:53 »
is there only one pump for washers ?? i assumed there would be one for front and one for rear..
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 21 March 2011, 21:58 »
Fit the correct pump with 2 outlets :lipsrsealed:
Thom
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 21 March 2011, 22:00 »
oh now i see how it would work  :grin:
Offline Sam
  • Sam I am
« Reply #4 on: 21 March 2011, 22:00 »
Early mk2s had a front bottle and rear, so only one outlet. You probs have the early pump
Offline Gloves88
« Reply #5 on: 21 March 2011, 22:10 »
Do you get pumps with two outlets?  :huh:
Its a modern pump that is meant to reverse polarity to do the front and back in one.
90spec mk2's have only one pump to do the front and rear, how is the piping set up with these?
The washer pump and piping have been removed from the mk2 I have so I cant check, hence the query  :smiley:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 21 March 2011, 22:16 »
One pump with 2 outlets...
The pipework goes through the bulkhead and along the drivers side of the car to the rear and then up the c pilar and through the RHD grommet on the tailgate and back down to the rear wiper unit AFAIK...
My car had a single outlet pump when I bought it, so both fronts and rears would wash when you powered the rears... 10 min job to change but it did have all the pipework in place..
« Last Edit: 21 March 2011, 22:18 by X4MGS »
For More Info Click To See;
Offline Thom89
« Reply #7 on: 21 March 2011, 22:41 »
Notice that the blue section has a blue outlet pointing downwards, at the other end, there is a black outlet pointing upwards :wink:
Polarity swap changes the direction of the motor, to give you water front or rear
http://cgi.ebay.co.uk/VW-GOLF-MK2-GTI-WINDSCREEN-WASHER-PUMP-C69-/200480846009?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ead96f0b9#ht_1491wt_907
Thom
« Last Edit: 21 March 2011, 22:44 by thom89 »
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #8 on: 21 March 2011, 22:44 »
Offline Thom89
« Reply #9 on: 21 March 2011, 22:47 »
Iv'e not seen my water pump for a long time, too fat :lipsrsealed: :rolleyes:
Thom
