Author Topic: Overheating Help!!  (Read 3186 times)
Offline newgti
Overheating Help!!
« on: 15 March 2005, 14:13 »
Hi I have a 99 Golf Gti T 20v recently the water temp gauge is climing higher and higher and the car is displaying "Stop", "check coolant" on the dash. I have checked and the water levels are fine! does anyone know what this might be!
Sugar79
Re: Overheating Help!!
« Reply #1 on: 15 March 2005, 15:01 »
temp gauge sender unit faulty???
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 15 March 2005, 15:04 »
i'll bet you ?1 its the water pump knackered :wink:
Offline newgti
« Reply #3 on: 15 March 2005, 16:07 »
when i drive fast it does it pretty fast when i slow down the temp goes down!
The radiator fans come on if i turn the aircon on but sont seem to when the car is hot!
I dunno if that makes sence!
Offline fei5al
« Reply #4 on: 15 March 2005, 17:42 »
Hi there,
I had a similar problem on mine, in my car the fuse holder on top of the battery which houses the fuse for the radiater fan had melted. The fuse is one of the 30 amp ones. My radiater fan never kicked in before only came on when a/c was on. The fuseholder cost me ?35 an engine has not overheated yet. Hope it gets sorted.? :wink:
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 15 March 2005, 18:45 »
Interesting, not heard that one before ! Worth checking that first mate it'll be a whole lot cheaper than replacing a water pump.
Offline chewy
« Reply #6 on: 15 March 2005, 21:34 »
the fans will come on if the aircon is turned on.they run constant untill you turn it off.i would agree it's either the temp sender unit or the waterpump
Offline bosun
« Reply #7 on: 16 March 2005, 08:39 »
Let it tickover and see if the fans come on.Usally if the propellor is loose on the water pump it works OK on tickover but not under load.Have you got any water flowing through the top pipe on the expansion bottle?This doesn`t usally flow when the pumps playing up.
Offline newgti
« Reply #8 on: 16 March 2005, 08:50 »
Thanks for all the input guys, ill check all this stuff out when i get in tonight and ill let ya know the outcome, though i did check the 3 fuses in the battery holder and they looked ok!
Thanks again!
Offline nrgizerbunny
« Reply #9 on: 16 March 2005, 10:21 »
I'd say waterpump.
LEave the car to cool for about an hour, put the heater in the "off" position and on cold.
let car idle, now grab the top hose that goes to the radiator, as the temperature increases you should feel the pipe get warm, you should be able to feel the coolant go through the pipe. Try squeezing the pipe and then you should be able to feel a bit better.
If you cant feel the coolant going round then its the waterpump.
