Author Topic: sorted starter motor squeal, but now ...  (Read 1296 times)
Offline andyj775
« on: 19 March 2011, 17:23 »
... the idling is all over the place. its sort of in a rhythm of dipping, then raising, then dipping etc. ive checked and re - checked all wiring/connections and checked over the coil wiring etc but cant seem to sort the problem. this has happened before when i last removed the battery, but it seemed to sort itself after a few minutes. this time has been well over 4 hrs. its a 2000 agu 1.8t. any ideas?
Offline phatsam2003
  • mk4 1.8T
Re: sorted starter motor squeal, but now ...
« Reply #1 on: 19 March 2011, 17:30 »
Mine did that after removing the battery, turned out to be a dirty throttle body.
Offline richw911
Offline andyj775
« Reply #3 on: 19 March 2011, 17:50 »
thanks very much, job for the morning then! thanks again will let you know how i get on
Offline andyj775
« Reply #4 on: 20 March 2011, 20:27 »
cleaned up the throttle body, was caked in crap. turned it over afterwards and was idling perfectly. job done! many thanks for the advice!
Offline richw911
« Reply #5 on: 20 March 2011, 20:27 »
Great stuff :afro:
