Author Topic: black head lining and black a,b,c pillars?  (Read 1773 times)
Offline tweed
« on: 19 March 2011, 13:23 »
I have fall black leather and want the hole interior black.
what do you use to spay the cloth head liner and then what spray and process to use on the plastic?
Offline tshirt2k
  • Been there...Done that...
Re: black head lining and black a,b,c pillars?
« Reply #1 on: 21 March 2011, 09:55 »
Doubt spray would give a good finish. I covered mine I faux suede. If you are going to remove it. May as well recover it properly.
Mk3 ABF 16VT Megasquirt V3
Offline tweed
« Reply #2 on: 21 March 2011, 20:03 »
I like your attitude! where did you get the suede from?
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 26 March 2011, 20:57 »
Plastic parts should be washed and Scotchbrighted with warm soapy water, dried and degreased, a light coat of a good quality plastic primer, the coated lightly in Satin black aerosol...and  NOT Matt black, this will give you an OE finish, thatll look like it came out the factory like it.
Vinyl head linings, can be sprayed with vinyl specific aerosols that are available with the other products needed from Halfords..
Thom
« Last Edit: 26 March 2011, 22:49 by thom89 »
« Reply #4 on: 28 March 2011, 23:44 »
Better to recover a mk3 headlining as it is board based and they do not spray well.
