I was trying to fix the needle on my tachometer, so I disconnected the cluster, took the plastic housing away (so that it was easier to get to) then reconnected the cluster. After tweaking the needle a but, I thought I'd check to see if it would now work..
As I put the keys in the ignition, one click before engine start, it went as follows:
BEEP, check brake pads, BEEP, Immobiliser activated, BEEP, check wash fluid, then shows mpg and temperature. The EPC light flashes throughout!
WTF is going on?! My pads are new, my fluid is topped up, n I've never had running issues of ECU problems!
Also, as the the immobiliser is activated, as soon as the engine starts up, it cuts out! I've already been out and about in the car this morning, without any issues or warning lights!!
Please help a fellow dubber in need!
