Author Topic: forge i/c to throttle body hose  (Read 1317 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« on: 18 March 2011, 21:05 »
Fitted mine the other week and the bend nr throttle body on the internal radius side looks a bit pushed in is it the case that i need to shorten the hose slightly ie take a small trim of that end to make it right? Also the ic end on the external rad is touching the bodywork lip if u understand wot i mean.just wondered if anyone had had the same thing and wot they did about it.hope this all makes sense.thanks.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline symsymma
Re: forge i/c to throttle body hose
« Reply #1 on: 19 March 2011, 18:34 »
Anyone? :huh:
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 19 March 2011, 18:38 »
my i/c to throttle pipe bends slightly mate but not much should be fine
Offline symsymma
« Reply #3 on: 19 March 2011, 18:43 »
It doesnt look to bad maybe lost 5mm of the overall diameter.just wondered all the rest of them fit pukka. :laugh:
Offline vwfiend
« Reply #4 on: 19 March 2011, 19:19 »
Have you tried twisting it slightly mate? The one with my Forge FMIC was rubbing on the back of the botyom of the headlight clip till i rearranged it. When its on boost itll puff out anyway mate  :smiley:
Offline symsymma
« Reply #5 on: 19 March 2011, 19:34 »
Yea was thinkin mayb a twist and a fiddle mite sort it if ull pardon the pun. :smiley:not a major issue if i cant get it ne betta though? :grin:
