Author Topic: Ive finally invested in a DA polisher  (Read 4690 times)
Offline JDM82
« on: 18 March 2011, 17:17 »
Ive invested in a DA polisher kit and id like to know if this is all ill need. Im new to this so bare with me.
My kit:-
1x DAS6 Dual Action Electric Polisher with 1x 5" backing plate.
1x Dodo Juice Waffle Polishing pad
1x Dodo Juice Waffle Finishing pad
1x Dodo Juice Lime Prime Polishing Compound 250ml
1x Dodo Juice Lime Prime Lite Finishing Compound 250ml
1x Roll of 3m 3434 25mm detailing tape
1x Dust remover Detailing Soft Head Brush
Is there anything else ill need or any advise wouldn't fall on deaf ears  :smiley:
Ive bought a black car and my usual by hand  :wink: system just doesn't work so I got myself a DA polisher.
GOLF GTi - The legendary hot hatch
Offline Dan J
Re: Ive finally invested in a DA polisher
« Reply #1 on: 18 March 2011, 18:04 »
nice bit of kit, just for the record lime prime and lime prime lite are not compounds, lime prime is a pre-wax cleanser with abrasives and lime prime lite is a pre wax cleanser glaze no abrasives.
if you havent got any already you'll need some sealant or wax to apply when you've finished polishing to protect the paint.
also claying before you polish will remove contminants from the surface making it smooth and ready for polishing.
Offline FOREST GREEN
« Reply #2 on: 18 March 2011, 19:45 »
If you've never used a machine polisher before, get an old panel from the scrappys and have a practice 1st............ :wink:
Offline JDM82
« Reply #3 on: 18 March 2011, 20:42 »
I already use lime prime etc and I thought they weren't compounds but Im still happy with my kit. I have chemical guys sealant and meguairs mirrior wax. Ive been using all the products just I thought id get better results with a machine polisher and it wont take me the amount of time it does at the moment to apply and remove all these products. Thanks for the comments/advise  :smiley:
Offline JDM82
« Reply #4 on: 18 March 2011, 20:52 »
I have some Meguiar's Ultimate Compound so when would I use this?
I have the lime prime and the lime prime lite. I then have sealant and wax so where would I fit in using the compound and with what type of pad?
My car is black and showing the usual swirls and lite scratches which I got the DA and compound for.
A list of what to use and in what order would be great  :smiley:
Offline Dan J
« Reply #5 on: 20 March 2011, 00:54 »
pre soak car with snowfoam if you have a snowfoam lance.
rinse off
wash car 2bm
rinse car
clay whole car
rinse
dry
ultimate compound on the polishing pad, do each panel in sections work the polish well into each section.
lime prime on the buffing pad again doing each panel in sections, lime prime is quite an oily product so has a long working time.
then apply lime prime lite by hand, wipe on wipe off, work in small sections again on each panel, no heavy pressure needed just apply with an applicator evenly and buff off straight away.
2 layers of sealant, buff inbetween layers
wax(is it #16 in the blue tin?) 2 layers applied thinly, buff inbetween layers.
stand back and admire the your hard work
Offline JDM82
« Reply #6 on: 20 March 2011, 08:50 »
As always Purple Haze, a detailed procedure, thanks  :smiley:
Yeah it is #16 in the blue tin.
I have a quality snowfoam lance but I think my actual foam is poor quailty, it never foams right, could you suggest a quality snowfoam?
I also have Pro Valet orange TFR. Its new on the waxomomo site so thought id give it a shot as its easier to apply than getting the pressure washer out and set up. Ive bought a quality pump sprayer to apply it or do you suggest sticking with the snow foam?
Thank you for the advice, ill do actually as you've said  :smiley:
Ive also ordered a soft cutting pad so would that be better to use with the cutting compound?
« Last Edit: 20 March 2011, 08:52 by JDM82 »
Offline Dan J
« Reply #7 on: 20 March 2011, 13:36 »
no a polishing pad is fine for what you want it for, you'd only need a cutting pad if you were doing heavy correction work like scratch removel etc,
whats the snowfoam you've got? and how much are you putting in the bottle before you top it up with warm water?
cool, megs#16 is a great wax, dampen applicator and put it on very very very thin, this stuff will give you grief if you apply it to thick and leave it on too long.
Offline JDM82
« Reply #8 on: 20 March 2011, 14:56 »
To be honest I think I must be doing something wrong  :undecided:
I have this foam http://www.theultimatefinish.co.uk/snow-foam/ultimate-snow-foam-5-litres.aspx
And according to the write up and customer reviews, its the best buy.
I don't get nice thick foam and it certainly does'nt cling on for very long so it must be me?
I have a quality 'proper' snowfoam bottle with brass fixings etc.
I put an inch of product in the bottle and fill the bottle up with warm water then attach it to my pressure washer and no matter how much I twiddle with the valve it does'nt seem to improve. I do get foam but not like on the video of the orange focus  :cry:
This is my foam lance http://www.theultimatefinish.co.uk/snow-foam/karcher-k-series-heavy-duty-professional-foam-lance-1l.aspx
« Last Edit: 20 March 2011, 15:01 by JDM82 »
Offline Dan J
« Reply #9 on: 20 March 2011, 16:08 »
ok how long have you had it? and have you used it quite alot?
the gause inside the foam lance could be bunged up with sludge etc from the solution, it builds up over time but can build up quickly if the solution is left in the head inbetween uses and not flush out with clean water.
also there could be a dirt or grit trapped somewhere in the head blocking the small holes and reducing the performance.
sorry for all the questions mate just trying to work towards a solution here for you;)
