Author Topic: front drivers side low  (Read 1557 times)
Offline bosco
« on: 18 March 2011, 12:24 »
Just wondering I put the subframe back on my mk2 and there seems to be very little clearance between the arch and the wheel on the drivers side?
The passenger side clearance is fine and so are the rears its just the front drivers side. I have switched the shocks etc on both sides to see if the problem followed the drivers side ones but it didnt.
Any ideas?
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline Benrevs
Re: front drivers side low
« Reply #1 on: 18 March 2011, 12:40 »
Are you on a slope?!   Check that the lower ball joints are slotted fully into the hubs. It should be visible if something isnt right. Have you driven it?
Offline bosco
« Reply #2 on: 18 March 2011, 13:25 »
no slope I thought it might be that. Will check the ball joints later on thanks. Driven it around the estate and nothing seems funny turns fine and goes in a straight line fine?
1990 mk2 1.6 daily
Offline cняis
« Reply #3 on: 18 March 2011, 19:50 »
knackered coil springs? possibly lost their strength or maybe a coil has snapped off?
Offline dan_apps
  • too low for british roads!
« Reply #4 on: 18 March 2011, 22:14 »
top mounts on correctly and spring sitting in housing properly?
Offline bosco
« Reply #5 on: 19 March 2011, 11:40 »
Any pics of how it should be properly set up?
1990 mk2 1.6 daily
