Author Topic: Few Probs....  (Read 2221 times)
Offline DimReefa
Few Probs....
« on: 14 March 2005, 23:24 »
Elo.I'm new to mk3's and ave just bought a 8v gti in flash red and just a few niggles with it which i hope someone could help me with..The drivers door lock just spins in the handle not doin nothing and when i pull the key out it comes about 3mm and the other thing is when i am goming to a stop and put the clutch and brake the revs will dip lower than tickover and now and again go low enough to cut out...
any info would be really appreciated..
mk3 noobie...
Offline nrs1
Re: Few Probs....
« Reply #1 on: 15 March 2005, 00:25 »
I HAD THE SAME PROBLEM WITH THE REVS AND THE CAR CUTTING OUT
READ ALL THE PAGES OF POSTS ABOUT GOLFS CUTTING OUT YOU WILL FIND THE SAME THIGN HAPENS TO ALL MK3
GOLFS/GTI'S
LOTS OF THINGS TO TRY CLEANING OUT THE THROTALL BODDY WORKED ON MY N REG 8V GTI.
HOPE THIS WILL HELP :wink:
madness is a state of mind or a mind in a state
Offline DimReefa
Re: Few Probs....
« Reply #2 on: 15 March 2005, 00:32 »
cheers i'll give it all a good clean breathers the lot
Thanks very much..
« Last Edit: 15 March 2005, 00:58 by DimReefa »
mk3 noobie...
Offline DimReefa
Re: Few Probs....
« Reply #3 on: 15 March 2005, 19:09 »
cleaning the throttle body and breathers as worked.....cheers
mk3 noobie...
Offline nrs1
Re: Few Probs....
« Reply #4 on: 15 March 2005, 20:30 »
Glad I could help
Sorry about the spelling on the last post late night and too much to drink not a good mix for hitting the right keys.
Offline kr1s77
Re: Few Probs....
« Reply #5 on: 16 March 2005, 17:13 »
what did you clean the throttle body with?
thanks
ASV 1.9 TDI 110
Offline DimReefa
Re: Few Probs....
« Reply #6 on: 16 March 2005, 17:19 »
Carb cleaner m8 and now it runs a dream its just the door lock prob i can't find any info on.So if anyone can help it would be much appreciated...
mk3 noobie...
Offline kr1s77
Re: Few Probs....
« Reply #7 on: 16 March 2005, 17:46 »
thanks for that, i'll give it a go when i can get round to it. sorry i can't help ya with your lock problem
ASV 1.9 TDI 110
Offline nrs1
Re: Few Probs....
« Reply #8 on: 16 March 2005, 20:25 »
WD40 and elbow grease
as for the lock had the same thing on a cavalier i had (sad but cheap) there was a clip on the inside of the door
that had fallen of
just had a look in the Haynes manual  think there i a retaining clip inside the door have to take the door panel of to get to the door lock
there is a connecting rod and spring
then there is a coupling and spring clip
if there are damaged this might be the problem???????
Offline DimReefa
Re: Few Probs....
« Reply #9 on: 16 March 2005, 23:32 »
Cheers very much. i must get me a manual for it...cheers for all the help anyway
mk3 noobie...
