Author Topic: Anybody know the height of this 4  (Read 12149 times)
Offline Steve_PD
Re: Anybody know the height of this 4
« Reply #70 on: 20 March 2011, 22:23 »
As i said before on the phone mate, the rear shocks are not as tall as the fronts, nor are the springs, the car should be level all round if you park on a flat surface, a fixed rate kit of say 40 mill shoulleave the car level all round but 40 mill down..
id say theirs some other issues if your car is not level, either that or your eyes playing tricks,
measure the bottom of the sill (to the ground - on level surface) just infront of the rear wheel and again just behind the front wheel. let me know the results
if you cant do this ill do it whn i see you
wrong. all mk4s are higher at the back. its how they where designed only way to get over it is to fit coilovers
Offline andc1
« Reply #71 on: 20 March 2011, 22:39 »
higher back than front = stance!!!!! :laugh: :laugh:
Offline Grand Master Patch
« Reply #72 on: 20 March 2011, 22:41 »
Higher back than front = rake,stance is a whole different ball game :tongue:
Offline brown29
« Reply #73 on: 21 March 2011, 19:23 »
From the pics there seems to be a 15 to 20mm difference from the front to back?
If I use shocks and springs will the front still look different to the back?
I want them to look the same on each arch.
Only way is to get coil-overs to guarantee that
Do you think replacing the front and back top mounts first on my standard suspension might make the current standard suspension sit right on both front and back aches?
Then I would know if the drop would go right with the shocks and springs solution.
hmmm problems problems  :laugh:
I replaced the entire suspension on my old Golf and there was still a difference between the front and back
I replaced the top mounts, shocks and springs
If you can lighten your engine you might get it level  :grin: :grin:
or put afew rocks in the boot  :grin:
Maybe this is why then, cause mk4's fronts are lower then the backs.
Can you put a pic up of your car mate from side on? would like to see it out of intrest.
« Last Edit: 21 March 2011, 19:26 by brown29 »
MK4 1.8T GTI
Offline brown29
« Reply #74 on: 21 March 2011, 19:27 »
Can anyone confirm this, are all mk4's higher at the back then they are at the front?
If so, why are they?
MK4 1.8T GTI
Offline vwfiend
« Reply #75 on: 21 March 2011, 19:29 »
Because their pretty gash.....
Offline brown29
« Reply #76 on: 21 March 2011, 19:59 »
yeah but why are they? they are plenty of people running coilovers who like them.
You can't just say they are gash and then just leave it, why are they gash? for what reason?
MK4 1.8T GTI
Offline vwfiend
« Reply #77 on: 21 March 2011, 20:36 »
Im running coilovers to attempt to make my golf handle and look better due to the back being so high. Its just how their designed. Their a comfy family vehicle more than a road race car like a GTI should be
Offline mikemk4gti
« Reply #78 on: 21 March 2011, 21:31 »
maybe if you got a full car with the shopping in the boot it might sit level?
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #79 on: 21 March 2011, 21:38 »
Bags of cement in boot work well :grin: :grin:
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
