Author Topic: mfa not working  (Read 7555 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
mfa not working
« on: 16 March 2011, 19:28 »
Hi all, I have recently purchased a 90 spec gti,All is well and im really happy with it.The only thing that niggles is the MFA does not do anything.However you move the toggle on the stalk nothing happens.
Im not sure where to start with it so i was wondering if anyone has any ideas or common causes why it is u/s
Thanks in advance
Offline dragonfly
Re: mfa not working
« Reply #1 on: 16 March 2011, 19:59 »
Is it blank or showing "---"?
Offline 01664gti
Re: mfa not working
« Reply #2 on: 16 March 2011, 20:28 »
I just have the clock showing and it doesnt do anything else
Offline dragonfly
Re: mfa not working
« Reply #3 on: 16 March 2011, 20:47 »
Have you pressed the end of stalk rather than the toggle switch?
Offline 01664gti
Re: mfa not working
« Reply #4 on: 16 March 2011, 21:03 »
yes i have pressed that and moved the toggle and re tried.It just continuously shows the clock.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: mfa not working
« Reply #5 on: 16 March 2011, 21:08 »
Does the clocks have MPG, Temp etc marked around the MFA display?
For More Info Click To See;
Offline 01664gti
Re: mfa not working
« Reply #6 on: 16 March 2011, 21:24 »
yes they are definatley the right clocks.I had a driver before and my gti says mpg temp etc around where the clock is.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: mfa not working
« Reply #7 on: 16 March 2011, 21:30 »
Sounds to me like someone has fitted a NON MFA unit with a rev counter...
You will have to do one of 2 things...
1, Take off the bottom cover of the stalk cover and see if the white 5 or 6 pin connector from the MFA stalk is connected
or
2, take the clocks out and check that they have the Vacuum unit in-between the rev counter & speedo... if they do make sure the Vacuum unit isn't broken but as I say I think someone has fitted the wrong clocks...
Offline tech1889
  • Mk2 GTI FTW !!
Re: mfa not working
« Reply #8 on: 16 March 2011, 21:36 »
stupid question my vac bit was plugged in back of clock but tube not into anything where it plug into ??
Re: mfa not working
« Reply #9 on: 17 March 2011, 09:52 »
sounds liek stalk or wiring problem, where is the hazard switch dash or column? try pulling dash fuse for 30 seconds might kick it back into life
